Factory Brake Pad Shim Kit - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 10-12-2011, 04:03 PM   #1 (permalink)
View ashcoal2000's Photo Gallery
I'm going to install a set of pads on a 2001 and this set came with a shim kit. Usually, I just reuse the old ones, but I'm planing on using new. This kit has a plastic film on both sides of the shims. I cannot determine if it is there to keep them from getting scratched or if the film is part of the shim that should be left on. To be clear, the film is on both sides of the shim and if I left it on, there would be a film layer between the pad and the shim (which I could see for anti squeal purposes) and then another layer between the shim an the piston, which I don't understand.
If anyone knows the answer as to whether to peel the plastic off or not, please let me know.
ashcoal2000 is offline   Reply With Quote
