Originally Posted by OldSienna00
The main issue is a problem with the muffler or cat, one of the two which would cost around the value of the car to fix.
Monroe makes what's supposed to be a good aftermarket - has a decent warranty too- and that will cost a lot less than OEM.
Have you had the front end aligned or looked at? Was the problem there before tires were replaced, maybe bad tire etc. All cars need maintenance. I'd run it longer.
You'll read here that a lot of that year Sienna make it well over 200k, some over 300k. The only expensive maintenance item is the timing belt/water pump and that ranges a lot. Find a knowledgeable local place and save a bundle on that, too. Repairs tend to be the same for all of them, the rear gate latch and some plastic trim fail.
