P0440 fix is summary, 02 Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 01-09-2012, 05:13 PM   #1 (permalink)
View jimmyb.1's Photo Gallery
P0440 fix it summary, 02 Sienna
Here's my fix it findings from my P0440 code. A P0440 is a Evap emission control system malfunction = emission related code. This code is often a two trip/tank failure so when you reset the CEL in two tanks it'll reappear. Possible simple solutions are a bad gas cap or a vacuum line pulled off the EVAP line. One extremely knowledgeable poster stated that the problem is "most likely a bypass VSV (vacume switching valve) located on the charcoal canister - they always go bad." Don't get this VSV confused with the other two VSV's located on the left and right sides in the engine bay. Page 6-22 in my Chiltons manual. When charcoal canisters fail, most of the time you will get a 440 and a 441 &/or a 446 code as well. I bought an OEM charcoal canister for $375 that came with all the valves (VSV) and solenoid stuff attached as one unit that I was needing. Basically I dropped the spare tire, pulled a shield and unbolted the canister. I would recomend an air gun b/c the threads will be rusty. Assembly was easy although I did make notes on what hose was hooked where. Hope this helps someone out.
jimmyb.1 is offline   Reply With Quote
The Following User Says Thank You to jimmyb.1 For This Useful Post:
TrailDust (01-24-2012)
Old 01-24-2012, 10:56 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3639350
Thank you for posting up both of those fix-it summaries, which is much appreciated!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
