DIY: gen1 blower motor resistor replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 01-20-2012, 11:13 PM   #1 (permalink)
How hard could it be?
uibalnme's Avatar
Gameroom cash: $447745
View uibalnme's Photo Gallery
Gen1 DIY: gen1 blower motor resistor replacement
I had a problem with my 98 Sienna's front blower slowly dying. Just last week it finally quit. I came over from the gen3 Camry forum to search for an answer, and found the info I needed. The likely problem was the blower motor resistor. I bought a new resistor (OEM part number: 87138-08010), and searched for a DIY on replacing it, but couldn't find one. I like working on cars, so, I didn't really need a DIY to do it. However, some may not be as mechanically inclined as myself. So, I decided to write one up.
Surprisingly, it's the easiest fix I've done to this van. It took me less than 5min. to replace it.
So, here it is...
First pry up the front edge of the door sill scuff plate. You don't have to completely remove it, just pry it up enough to allow removal of the kick panel. I just used my bare hands, but a flat head screwdriver might make it easier for others
Next, remove the kick panel, by removing the small plastic nut at the front edge of the panel near the carpet, lift the panel away from the bolt, and pull the panel away from the dash to release the clips that hold it on.
With the kick panel out of the way, you can now remove one of the 10mm hex bolts that holds the lower dash panel on.
The other 10mm hex bolt is pretty much out in the open on the opposite corner of the panel.
With the bolts removed the only thing holding the panel on are a set of clips on the top edge of the panel. Just pull the panel away from the dash to remove it, and gain easy access to the resistor.
Remove the two screws holding the resistor in, pull the resistor out, unplug the old one from the wire harness. Installation is the reverse.
Here is the old resistor. You can see the corrosion all over the copper connections.
There you have it. A quick, and simple fix to a faulty front fan. Enjoy!!!
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline   Reply With Quote
The Following User Says Thank You to uibalnme For This Useful Post:
TrailDust (01-24-2012)
Old 01-24-2012, 10:59 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3639350
Thank you very much for taking the time to post up that DIY! Efforts like yours are always appreciated!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 05-24-2012, 04:11 AM   #3 (permalink)
pwrmactx's Avatar
View pwrmactx's Photo Gallery
is this to solve the fan noise issue?
pwrmactx is offline   Reply With Quote
Old 05-24-2012, 06:52 AM   #4 (permalink)
Dave's
Gameroom cash: $124850
View Dave's's Photo Gallery
Should be to solve the fan speed issues. If one or more speeds 'disappear' or it only works at full speed then it's most likely this resistor pack. Most are electronic now vs the old wire-wound resistors. JMHO, but the most common reason for this failure to occur is the resistor pack, either because of corrosion from some moisture problem such as condensation or a very dirty cabin filter which restricts air flow from keeping the resistor pack cool.
Dave's is offline   Reply With Quote
