Cleaning the IAC - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 01-29-2012, 11:15 AM   #1 (permalink)
View szhk's Photo Gallery
Cleaning the IAC
I am trying to remove TB in order to clean up the IAC. there are 2 hoses with slip rings in front of the TB. one of the the hose is connect to a hose marked FUEL, another one have water leaking out even i try to discount (so I stopped when see water). Can I discount those 2 hoses? and the 3rd bolt holding TB is under the TB, I can not reach to remove it, what I can do to remove the 3rd bolt?
thanks in advance.
szhk is offline   Reply With Quote
Old 02-22-2012, 11:17 AM   #2 (permalink)
View toyotaman007's Photo Gallery
Canada
you will loose some coolant. just have a screw close to the same size as the ID close by to plug the hoses. you will need an extra long extension bar for the ratecht set to get to the other screw. You should do this repair with a repair manual handy. you alsp need new gasket set.
2010 Venza 4Cyl AWD, Cdn Premium Package
2003 Matrix XR red Stock
2002 Sienna XLE, pwr doors, VSC + more Toys with troubles
toyotaman007 is offline   Reply With Quote
Old 03-04-2012, 06:34 PM   #3 (permalink)
View wiswind's Photo Gallery
There are coolant lines connected to the throttle body.....coolant flows through it.
I cleaned mine on the vehicle, it sounds like removing the whole throttle body to clean it is a lot of work.
I might be wrong, I have not removed mine, but I think that you can remove / replace the IAC without removing the whole throttle body.
wiswind is offline   Reply With Quote
