well, here's what happened. a year ago one of the 02 sensors went out. I just drove it and didn't replace it. About a week ago we went to a night class at school. Turned the car off, and then came out after class, ( couple hours passed ) got in to start the car and it would not start. It was snowing that day so I didn't really get to check it out that well. It was freezing outside. I disconnected the airbox from the intake, I sprayed some starting fluid down in there and attempted to start the car. It wouldn't do anything but turn over. Every once in awhile, it would act like it was gonna try to fire but would continue to turn over really fast almost like it was free spinning. I thought it had jumped time to be honest. My mechanic went up there to get the van and he couldn't get it to start either UNTIL he depressed the gas pedal some. As soon as he did it, the car fired up but he had to hold the gas down when he came to a stop light to get it to continue to run. He drove the car home, ran his tests and came back to tell us that both upstream 02 sensors were bad. After he replaced them, apparently when he flashed the computer, he couldnt get it to idle right. He flashed it a second time with the same result. Then according to him, the third time he picked some "generic" flash off of his computer. The car runs perfect driving it down the road. Its just when you first start it in the morning, it doesnt seem to "choke" itself. You have to hold the pedal down to get it to start and then drive it down the road a little before it will run on its own. However, when you come to a stop sign or light, it drops down to 400 rpm at idle. I have also noticed that the when the car starts, it doesnt turn over the the same. It seems to really turn over fast.
I was actually dreading "thinking" about the problem being related to those bosch 02 sensors. I hope that has nothing to do with it. :/
One other thing, he told me that he pulled the threads out of the second bank in the exhaust manifold when he pulled out the old 02 sensor. He said he had to re-tap the hole. I don't know if this is true or not. I have the old 02 sensors and see no evidence of metal flashing anywhere within the grooves of the 02 threads. He had my van for too long and im not sure what he did that I believe and do not believe. Neverthaless, I hear no exhaust leak and that 02 sensor is staying in.
