bolt tighening pattern for valve cover on 2000 sienna? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 02-12-2012, 10:52 AM   #1 (permalink)
View Teachndad's Photo Gallery
Hi,
Can someone tell me the bolt tightening pattern for tightening the valve cover after I replace the old valve cover gasket and install a new one?
thanks
rod
Teachndad is offline   Reply With Quote
Old 02-15-2012, 10:35 PM   #2 (permalink)
View tennsienna's Photo Gallery
Rod,
The 1999 Sienna Repair Manual instructs to "uniformly tighten the [8] bolts in several passes." Tighten the bolts to 8 N·m (69 in·lb).
My method is to begin by tightening the bolts, using a circular pattern, to 1/4 the final torque. Then I make a second pass, tightening to 1/2, then a third pass to 3/4, then a fourth pass to the spec value, and then a final pass to recheck the bolts at the spec value.
I hope this helps.
Bart
tennsienna is offline   Reply With Quote
The Following User Says Thank You to tennsienna For This Useful Post:
Teachndad (02-16-2012)
Old 02-15-2012, 11:59 PM   #3 (permalink)
Yes, Bart, thank you, it really helps!
Cheers
Rod
