Aftermarket brake pad recommendations for '99 Sienna? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 03-10-2005, 06:00 PM   #1 (permalink)
View cinepro's Photo Gallery
Just wondering if anyone has a recommendation for aftermarket brake pads for my '99 Sienna. I was just going to get some Raybestos at Pep Boys, or perhaps Napa.
Will aftermarket pads (and rotors, if needed) introduce problems with warping? If so, which pads are OEM?
cinepro is offline   Reply With Quote
Old 03-15-2005, 02:45 AM   #2 (permalink)
SiennaSC98's Avatar
View SiennaSC98's Photo Gallery
I'm using the EBC 6000 series pads and Brembo sport drilled rotors. This ombination of brake and rotor stop much better and more responsive hot or cold condition.
SiennaSC98 is offline   Reply With Quote
Old 02-16-2006, 11:16 PM   #3 (permalink)
rwd_3tc
View rwd_3tc's Photo Gallery
just use original. its much better then the aftermarket equipmet
rwd_3tc is offline   Reply With Quote
Old 02-19-2006, 08:33 AM   #4 (permalink)
Frank@toronto's Avatar
View Frank@toronto's Photo Gallery
Ceramic brake pads seem to last much longer.
Frank@toronto is offline   Reply With Quote
Old 02-22-2006, 11:48 PM   #5 (permalink)
View renegade141's Photo Gallery
just dont buy cheap aftermarket pads that dont come with anything but the pads
make sure you get the anti squeal shimms, and grease with it
if u get cheap aftermarket pads, make sure you grind down the pads on a angle to eliminate high pitch squeaks when braking
renegade141 is offline   Reply With Quote
Old 05-16-2006, 09:42 AM   #6 (permalink)
View Pooka's Photo Gallery
AM Brake Pads
The OE pads are ceramic so I would recommend using ceramic pads for whatever brand you choose. I used Bendix ceramics and replaced the rotors too. No problems at all (although I did have one caliper slide pin that was frozen and had to "free" it).
Pooka is offline   Reply With Quote
Old 05-16-2006, 09:42 PM   #7 (permalink)
View camlex's Photo Gallery
Thermo quit
Hello,
I have 99 Sienna. last month i did replace with Thermo quit from Orailly for $44
I really like it. better then previous toyota pads.
Hope that helps.
camlex is offline   Reply With Quote
