Disable DRL for my 01 Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 04-03-2005, 04:01 AM   #1 (permalink)
View suprawrx's Photo Gallery
I would like to install my HID kits but unable to dsable the Daytime Running Light. I tried to remove the DRL relay from the fuse box in front of engine bay, but can't turn on the light once it take off.
I get the TSB for solving this issue by cutting 1 of the ECU connecting wire, but.....D4 is which one?Here is the link.
http://www.planetkc.com/rande/tsb/El011-00/El011-00.htm
I need ECU diagram...
suprawrx is offline   Reply With Quote
Old 01-16-2006, 01:11 AM   #2 (permalink)
View gekishibu86's Photo Gallery
First locate the DRL relay. It's located to the right of the steering wheel column below. Run your hand by that panel and feel for a box about 4x4" and unplug the 14 pin wire harness. With the harness facing you with the lock on top, count from the top left and cut the #2 wire (gray), secure and insulate with electrical tape and your done.
gekishibu86 is offline   Reply With Quote
Old 01-27-2006, 03:34 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
Can't you pull out the DRL fuse?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-27-2006, 10:46 PM   #4 (permalink)
When I removed the fuse, DRLs are still on and was getting frustrated. My search lead me to this site that has the Toyota TSB for the correct way of disabling DRLs.
http://vamp.darkravers.net/DIYDisablingDRLs.cfm
Old 03-11-2006, 05:38 PM   #5 (permalink)
View gabcoppola's Photo Gallery
Any one knows how to activate my DRL in my rav4 2006? I already have the 3 relays that come on the fuse box, two blues and one brown. thanks
gabcoppola is offline   Reply With Quote
Old 11-01-2007, 08:32 PM   #6 (permalink)
Noob
View gladis's Photo Gallery
Is there a way for you to take the wire out without having to cut it? I want the process to be reversible.
I took several pictures of the plug if it will help.
gladis is offline   Reply With Quote
