oxygen sensor replacement on 2001 Sienna? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 06-10-2005, 10:28 AM   #1 (permalink)
View loshjott's Photo Gallery
The "check engine" light came on in my 2001 Sienna. I brought it in to the garage, the mechanic did diagnostics and said one of the oxygen sensors needs replacing. He quoted a price of $425. He said it is drivable until replaced, but that the sensor would need replacing to pass the emission test. I live in Maryland. Does this sound accurate and legit? Thanks.
loshjott is offline   Reply With Quote
Old 06-15-2005, 04:17 PM   #2 (permalink)
View vicchang's Photo Gallery
Hi, my 2000 Sienna had the same problem couple weeks ago. I called couple Toyota dealers for quotes. They want charge from $400 - $550. So the price you got is not too off. But if you want to avoid the expensive labor, one of my friends has a private garage in College Park area. He replaced the sensor for me for $320 parts and labor (genuine Toyota parts). I think that's a pretty fair deal. So, maybe he can help you on this if you are not too far away from his garage. Let me know.
Victoria
vicchang is offline   Reply With Quote
Old 08-18-2005, 03:58 PM   #3 (permalink)
Steve
View sreisiger's Photo Gallery
Oxygen sensor may not be the problem
My check engine came on as well and I failed the emission test with a P0171 and P0174 "running too lean" - The problem was with the Mass Airflow Sensor (MAF). It sits between the air filter and the throttle body. I took it out (2 screws and a clip) and the inside of the tube looked somewhat dirty. Sprayed carb cleaner in there a couple times and plugged it back in. Seems to have done the trick. A new one is about 75 bucks. Van no longer has a buzzing sound on acceleration. I thought this was the exaust heat sheilds but in actuality the engine was knocking due to the improper fuel/air mixture because of the dirty MAF.
sreisiger is offline   Reply With Quote
Old 12-13-2006, 10:48 AM   #4 (permalink)
View mikhett's Photo Gallery
I did mine
in a 1/2 hour.On a 01 v-6 the front one is right there behind the radiator,You must have a 7/8 o2 socket,Just unclip the electrical connector and replace. Part cost 185.00
mikhett is offline   Reply With Quote
Old 03-21-2009, 10:15 PM   #5 (permalink)
View Dr Know's Photo Gallery
2001 Sienna two too-lean codes
Thanks, Sreisiger! I had the same problem in 2008 on my 2001 Sienna, two codes, P0171 and P0174 I think, both reporting "too lean" mixture, plus occasional engine hesitation. Not believing a local mechanic's guess that two sensors could fail simultaneously, I searched for a common root problem.
After seeing what you wrote, plus similar thoughtful discussion on http://www.aa1car.com/library/ford_lean_codes.htm, I agreed with trying the cheapest solution first: I gently removed the mass air flow with a Philips screwdriver, sprayed the heck out of it with a half-can of "CRC MAF sensor cleaner", put it back, and reset the engine check light by pulling the EFI fuse for a minute. The check light stayed off, and all has been well ever since for over a year ... almost.
Only other problem was an air-fuel ratio sensor that actually did fail some months later. Perhaps just old age, unless I caused it by driving with a bad mixture a little too long.
Dr Know is offline   Reply With Quote
