Fuse Problem with Toyota Sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 07-11-2005, 03:11 PM   #1 (permalink)
View durbin1's Photo Gallery
Hi to All,
I own a 2001 Toyota Sienna which actually has been running quite well until just recently. The fuse that controls the clock and power doors seems to blow quite often now and I don't know what that means. When I read the manual it says that this could be a major problem, but I don't know enough about cars to know if this is true or not. The dealer has been helpful, but I pay quite a bit for their help! Any advice? My email if you prefer is marc.invergo@uky.edu
Thanks!
durbin1 is offline   Reply With Quote
Old 09-03-2005, 01:43 PM   #2 (permalink)
View WeileMom's Photo Gallery
Did you ever discover or fix this problem? Just curious.
WeileMom is offline   Reply With Quote
Old 03-16-2009, 02:18 AM   #3 (permalink)
View toyrub's Photo Gallery
I have same car with same problem, any help will be appriciated.
toyrub is offline   Reply With Quote
Old 06-21-2009, 09:37 PM   #4 (permalink)
Astute Toyota User
View Jimboroony's Photo Gallery
I once manually held the cigarette lighter in too long in my 2001 Sienna. The lighter and the clock no longer worked until I replaced the fuse. (Behind the little door to the left of the steering column that I thought was a coin bin or something)
As for the doors, they are a known big problem that does not seem to have a good fix. Both of mine are messed up but are manually operable.
Jimboroony is offline   Reply With Quote
Old 06-22-2009, 04:05 PM   #5 (permalink)
There was a short in my cars driver side sun visor, I cut the wire ( which was melted) and problem solved, thank you guys for response.
Old 09-02-2011, 06:52 PM   #6 (permalink)
View Samboyan's Photo Gallery
how to I access that area? do I have to remove that little door? My AC outlets are not working and a couple of days ago my wife took the car to the car wash and now the power mirrors are not working. Any help will be appreciated, thanks.
Samboyan is offline   Reply With Quote
Old 09-03-2011, 11:00 PM   #7 (permalink)
USA
Yes behind that little door is the fuse box, I suggest you to pull the fuse out and check for continuity out side , the second and third fuse boxes are under the hood next to the battery.
Good luck.
Old 09-04-2011, 04:55 PM   #8 (permalink)
View SiennaDriver's Photo Gallery
Never mind, just saw the date on this and extend my deepest sympathy if it's not resolved yet.
SiennaDriver is offline   Reply With Quote
