Transmission solenoid 98 sienna - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 1st Generation (1998-2003)
1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
Old 08-16-2005, 07:00 PM   #1 (permalink)
View ronman's Photo Gallery
my check engine light was on, so i took the 1998 sienna to a mechanic he said the tranny solenoid needs to be replaced. I am not sure if i believe him but he wants to charge me $435.00 for the work, is this a fair price? should i go to toyota and have them do it? does anyone know what will happen if i do not change the part? thanks everyone
ronman is offline   Reply With Quote
Old 08-17-2005, 02:59 PM   #2 (permalink)
solenoid tranny
the mechanics at toyota said that the solenoid is not a big deal, is this true? can i drive it without hurting the tranny? help
Old 08-22-2005, 09:13 AM   #3 (permalink)
Noob :-)
View ST185's Photo Gallery
I've done some research for you.
The transmission has several solenoids, depending on which one, it might be pretty easy to access and would not cost $$$$ to replace. I might be wrong but this transmission is the same as Camry and Avalon unit. They probably share the same part. In this case, a local junkyard might have the part for you. Some one please chime in. By the way, the brand new transmission is about $1860 with core.
Did you try to get an estimate from AMMCO?
They'll give you free diagnostic.
http://www.aamco.com/
Here is the location
http://www.aamco.com/main/locateacen...teacenter.html
93 ST185
ST185 is offline   Reply With Quote
Old 08-22-2005, 03:20 PM   #4 (permalink)
tranny
thanks for checking this out for me i will look into , but i am not sure if i should just drive the car until and if something happens? it seems fine to me.
Old 08-25-2005, 11:17 AM   #5 (permalink)
Noob :-)
Worst thing that could happen is you got stuck, and it won't shift into gear.
Get AAA plus and they will tow the car up to 100 miles free.
BTW, I suppose to fly back to Boston today but all fights were cancelled because of the storm.
I don't know should I be or
93 ST185
Old 08-27-2005, 05:28 PM   #6 (permalink)
have a good trip
have a nice trip
Old 09-15-2005, 12:07 PM   #7 (permalink)
View siennadad's Photo Gallery
Ronman:
I have a 98 Sienna at independent Toyota repair shop right now with same problem waiting on repair estimate for P0770 Shift Solenoid E Malfunction. What was your outcome/repair charge?
FYI - Found a doc online that indicates Shift Solenoid #1 backs up Shift Solenoid #2 and visa-versa in the event of failures. If both fail you can still drive car manually using column gear selector. L=1st gear, 2=3rd gear, and D=Overdrive.
Siennadad
siennadad is offline   Reply With Quote
Old 09-15-2005, 02:10 PM   #8 (permalink)
View deekay140's Photo Gallery
depending on the solenoid, you usually have to drop the pan and the valve body. so 300ish in labor is not that bad.
deekay140 is offline   Reply With Quote
Old 09-15-2005, 03:27 PM   #9 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
On my friends Accord, when the Shift Solenoid went bad it would not automatiicaly up or down shift. You had to manually go into d1, shift up to d2 etc and down. Also 1st and 2nd gears were inaccessable. Taking off in 3rd wasn't so bad, just kinda silly to only have a high and low gear.
drunken_panda is offline   Reply With Quote
Old 09-16-2005, 10:17 AM   #10 (permalink)
Thanks for the replys. Looks like it is the Lock up SS. Repair quote still pending.
