How to change Spark Plugs for 2001 SIenna XLE - Toyota Nation Forum : Toyota Car and Truck Forums
Sienna 1st Generation (1998-2003) Discussion area for the first generation Toyota Sienna.
post #1 of 9 Old 03-07-2009, 05:10 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Please guide how to change spark plugs.
atifkm is offline
post #2 of 9 Old 03-08-2009, 01:30 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
bump
atifkm is offline
post #3 of 9 Old 03-08-2009, 02:01 PM
Quoted: 2 Post(s)
Try the AutoZone Websites Vehicle Repair guide section.
Do a TN history search on chainging sparkplugs 1MZ-FE. This engine was used in Camry, Avalon.
toyomoho is offline
post #4 of 9 Old 04-04-2009, 05:28 PM
Quoted: 0 Post(s)
I just changed the six spark plugs of my 2000 Sienna a couple of weeks ago at around 85k miles. It's not that easy to change the back three plugs, but I succeeded to replace them without removing any parts.
There're several how-tos found on web, it's very helpful. They gave me confidence on how to do the job.
Tools I used: a 3/8 rachet, a 6-inch 3/8 socket extension bar, and of course, the 5/8 spark plug socket. I used a 3/8 stanley rachet bought from Walmart, still a little big. Later I found a very short husky rachet from home depot, it would be great if I had used this husky one.
The front three are very easy. Since you can't see the back three plugs, it's better to locate their position first. I just put my hand to the back of the engine and found the three boots before I even started, so that I know it's doable for me (My hands are not big, an advantage here), then I used my daughter's small mirror to check what are there and made sure I was right.
When you work on them, you have to learn your body on the engine part, so be sure the engine are cool down at that time.
I changed the right one first. First pull off the boot, then slowly slide in the 6inch extension with spark plug socket, then attach the rachet. Took the old plug out, put the new plug in. The middle one is the same thing, working from left side. The left one took more time, 'cause there's lots of wires there. Had to unclip the spark plug wires first.
It took me around two hours, lots of time spending on blindingly sliding in the socket, finding the holds, and attaching rachet. It needs patience and perseverence.
I used NGK iridium plugs and it's great. My wife told me the next day that she could feel the engine much more powerful than before.
la99 is offline
The Following User Says Thank You to la99 For This Useful Post:
Shakman959 (08-30-2011)
post #5 of 9 Old 04-05-2009, 09:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
great job.
I don't know why they located plugs like this to give everyone a hard time.
la99
can u let me know, how much fuel consumption is improved by that.
thanks.
atifkm is offline
post #6 of 9 Old 08-28-2011, 10:59 PM
Quoted: 0 Post(s)
I just replaced my spark plugs on my 98 Sienna. It took about as much time as it did for me to figure out how to register for this website and make this post. The Hanes manual had you removing the upper plenum, which I'm glad I didn't do as it was quite a bit of work. You can change the back three plugs without too much trouble. It's really the back plug on the passenger side that is a little tricky. The other two in the back weren't that hard. Like the other user said, its a good idea to take a quick look with a mirror to see what you are up against because most of the work is out of view. I got the job done with just a standard 3/8 socket set and extension with a spark plug socket. No universal needed.
rmingo is offline
The Following User Says Thank You to rmingo For This Useful Post:
post #7 of 9 Old 11-03-2014, 09:39 PM
VehicleWhisperer
Quoted: 1 Post(s)
I replaced mine (@73k) last weekend. I stumbled onto a helpful, human body-saving trick.
I was repairing the hood strut pivot/anchor (the ring-shaped thingy on the vehicle's RH side), so while the epoxy cured I had the hood propped open to nearly its maximum amount. This enabled additional space for my head, which I rested upon several folds of an old car wash towel placed on the cowl vent. This reduced the amount of break time required after each rear plug.
2000 Sienna CE 3 Door 260,000 Miles - Uses 1.5 quart of Pennzoil in 7,500 miles!
VehicleWhisperer is offline
post #8 of 9 Old 11-26-2014, 04:41 PM
Sr. Member (アンソニー ムクゴーアン)
mcgowaw's Avatar
Quoted: 922 Post(s)
we removed the cowl vent to do this and it helps alot. the wipers have to come off and a couple of air hoses but it's worth it to have that extra foot of room up over the top of the plugs for an assortment of extensions, swivels and ratchets to do the job.
tony
mcgowaw is online now
post #9 of 9 Old 07-26-2015, 11:33 AM
Quoted: 21 Post(s)
tony
I agree completely; I just finished mine and it was fairly easy to access the plugs with the cowl/wipers removed. Probably didn't take more than 15 min to take the cowl assembly out. I waited until I was replacing the struts at 167k mi and had to remove the cowl anyway to access the top strut mounts. With two 6" extensions the rachet is above the back of the plenum and you have full clearance to loosen and tighten the plugs. I used NGK 4589 laser iridium plugs. The NGKs I removed still looked great after 167k miles.
I was using a 2001 shop manual which said you need to remove the wiper motor linkage separately to remove the cowl. This was not the case in my 2002, the motor and linkage all came out with the cowl, I didn't need to dis-assemble it.
____________________
Keithmat
2011 RX350, 2007 Camry Hybrid, 2002 Sienna XLE, 2000 Miata SE
keithmat is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > Sienna 1st Generation (1998-2003)
User Tag List
Linear Mode Linear Mode
Back
