2005 Sienna Rear Wiper Replacement!! - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
post #1 of 12 Old 12-14-2007, 09:39 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Why can't I find any auto parts stores that carry replacement wipers for the rear window of my 2005 Sienna? It's so bad I can't see a thing!
kjjb0204 is offline
post #2 of 12 Old 06-02-2010, 09:48 AM
jeff618's Avatar
Quoted: 0 Post(s)
Thumbs up 2004-Mid 2005 Toyota Sienna Special Rear Wiper Blade
I'm assuming that you have a "Early Production" 2005 Toyota Sienna that has the special rear wiper arm and takes the special rear wiper blade. Here you go: Trico Exact Fit Rear Integral Blade 14-A. Easy install - comes with replacement and removal instructions.
Basically all 2004's have the special rear wiper. For 2005's, if you have a rear wiper that looks like one piece, you have the early production and you'll need the special blade. If your rear wiper looks fairly normal, then you have a late production and simply need a fairly standard 16".
First Time Caller, Long Time Listener, Great Topic, Love The Show...Thanks For Taking My Call
jeff618 is offline
post #3 of 12 Old 06-02-2010, 02:29 PM
Quoted: 0 Post(s)
When I've not been able to find precise fits, but needed a replacement, I've just gotten the rubber insert and cut it to size. Just voicing an alternative to the whole plastic arm/blade replacement, since all you really need is the blade.
2005 LE AWD
racerd is offline
post #4 of 12 Old 06-03-2010, 10:43 AM
jeff618's Avatar
Quoted: 0 Post(s)
Arrow Wiper Refill Inserts Vs. Wiper Blades
Yes - you can definitely go with wiper blade refill inserts, just need a little more mechanical ability and patience. I go with complete wiper blade replacement because our Wisconsin Winters are brutal on wipers as well as the wiper frames. I figure replacing the whole assembly - albiet a little more expensive - is just good insurance. Better safe than sorry.
Either way - make sure you lookup the correct refill or wiper blade part numbers for the brand you go with because they are not created equally!!
jeff618 is offline
post #5 of 12 Old 06-06-2010, 11:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Yeah, thanks for digging up a two year old thread. Haven't had that POS Sienna since about a month after my original post. I'll never buy another Toyota. I knew when I bought it I made a mistake.
kjjb0204 is offline
post #6 of 12 Old 06-08-2010, 01:40 AM
Quoted: 0 Post(s)
Well, it did help me out with my 2004
2004 Sienna LE, FWD, 8pass purchased new 07/03
currently at 135k miles
siennaman2004 is offline
post #7 of 12 Old 06-09-2010, 09:33 AM
jeff618's Avatar
Quoted: 0 Post(s)
Arrow
Cool - that was the intention. AND, you probably got it done without bumps and bruises on your forehead from banging your head on the wall!! LOL
jeff618 is offline
post #8 of 12 Old 06-09-2010, 02:50 PM
Quoted: 0 Post(s)
Anyone know if it's possible to convert the 2004 style wipers to the 2006 style wipers so there are more blade choices?
bcwang is offline
post #9 of 12 Old 06-10-2010, 07:50 AM
jeff618's Avatar
Quoted: 0 Post(s)
Arrow
I don't know personally but would guess the entire arm can be swapped out with the newer, more standard arm. I'm guessing the convenience of having blade options will not off-set the cost of the arm and possibly labor to swap it. I will say that once you find where to get the special rear blade (link above) for the special rear arm, it works fine and installs easy. Found an install video.
jeff618 is offline
post #10 of 12 Old 06-10-2010, 12:47 PM
Quoted: 0 Post(s)
I do see a wiper arm part for the rear lift gate for $32 for the 2005-2010 style, I wonder if that's all that will be needed. If the trico blade performs well, it won't be necessary. But if it sucks and you can replace it with any aftermarket blade, for $32 it's not bad. I'm not sure if every other part is the same though, such that you can simply swap arms. Hopefully that is the case.
bcwang is offline
post #11 of 12 Old 06-10-2010, 02:42 PM
Quoted: 0 Post(s)
^^ that video makes it look even easier than replacing the front blades... even if it's a bit more $$$, probably less headache than trying to cut refills and the metal support pieces to stuff them into the OEM blade.
Act162this is offline
post #12 of 12 Old 06-11-2010, 11:54 AM
jeff618's Avatar
Quoted: 0 Post(s)
Arrow
AMEN!! The only thing lower than my level of mechanical skill, is my patience level...in other words, no refill inserts for this guy...the assembly is much easier.
jeff618 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
User Tag List
Linear Mode Linear Mode
« Back
