Satallite radio question - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 02-23-2008, 12:27 PM   #1 (permalink)
Ride it lika ya stole it!
Mixednuts's Avatar
View Mixednuts's Photo Gallery
I'm installing Sirius radio in the wifes 2004 Sienna.
Where's a good place to put the antenna?
Pete
Mixednuts is offline   Reply With Quote
Old 03-04-2008, 12:10 AM   #2 (permalink)
View supra88's Photo Gallery
If you are asking about the xm antenna, run the cable to the back remove the molding around the cargo area in the back and run the cable up and put the antenna in the roof all the way back middle of the roof
if you have a sunroof you can also install in front of the sunroof or the back of sunroof
if you are asking for the radio antenna fm modulator,don't use it the audio is very bad when the vehicle is moving use a auxiliary audio input works in all Toyota radios
http://www.oemautosound.com/pc-340-1...2003-2006.aspx
good luck
supra88 is offline   Reply With Quote
