2008 Sienna Oil and Filter - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 02-23-2008, 04:33 PM   #1 (permalink)
View Jaketab's Photo Gallery
My 2008 Sienna is due for the 1st oil change. Could someone tell me where the oil filter is located on this vehicle? There is a cannister on the front side of the engine just below the exhaust manifold. Is that the filter housing?
I would also like to hear from others if they have been using synthetic oil and how it is preforming.
Thanks - Jaketab
Jaketab is offline   Reply With Quote
Old 02-25-2008, 08:26 AM   #2 (permalink)
tacojet's Avatar
View tacojet's Photo Gallery
You are looking at the filter housing. You need to get the filter element from the dealer, it will come with the o rings and a fitting to drain the filter.
use a 3/8" drive to remove the filter drain cover, drain it. Next, use a 65mm 14 Flute filter wrench to take the filter out.
tacojet is offline   Reply With Quote
Old 02-25-2008, 09:36 AM   #3 (permalink)
tacojet,
Thanks for reply. AutoZone had the filter element with o-rings and fitting.
Is the best access to the filter from topside or underside?
Jaketab
