2005 Sienna Transmission Fluid Capacity? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 06-04-2010, 01:22 AM   #1 (permalink)
View ID_hauler's Photo Gallery
What is the 2005 Sienna LE transmission's total fluid capacity?
I would like to know how much fluid would be necessary to fill a bone dry transmission.
Thanks!!
ID_hauler is offline   Reply With Quote
Old 06-04-2010, 10:20 AM   #2 (permalink)
View typesix's Photo Gallery
Should be in owner's manual.
typesix is offline   Reply With Quote
Old 06-04-2010, 02:44 PM   #3 (permalink)
The manual only gives the drain and fill capacity.
Old 06-22-2010, 06:36 PM   #4 (permalink)
View pjlee42's Photo Gallery
I just changed mine. I went to the dealer. And the parts department sold me 4 Qt. It is about the correct amount for drain and fill.
pjlee42 is offline   Reply With Quote
Old 06-22-2010, 07:59 PM   #5 (permalink)
View siennaman2004's Photo Gallery
4qts does not include the torque converter
I think the total is 9-10 qts total... sorry I couldn't be more help
2004 Sienna LE, FWD, 8pass purchased new 07/03
currently at 135k miles
siennaman2004 is offline   Reply With Quote
Old 06-24-2010, 02:10 PM   #6 (permalink)
Thanks for the input guys, you helped me realize I can just buy a bunch of quarts and just return the bottles I don't use.
I have 110k miles on my 2005 Sienna now and will be switching the ATF to Mobil1 synthetic. They blend the OEM T-iv fluid for Toyota so I have confidence that when they say their Mobil 1 synthetic is T-iv compatible, I believe them.
I'll let you know if I feel any difference or see any change in gas mileage.
Thanks!
Old 06-24-2010, 04:41 PM   #7 (permalink)
Thanks!
Mind me asking how you will be getting all the tranny fluid out of the tranny?? I need to do the same for mine.
Old 06-24-2010, 09:01 PM   #8 (permalink)
View wiswind's Photo Gallery
I have a 2003, which may be a bit different.
I drained the pan.....measuring what came out......removed the pan, measuring the additional fluid that I got out......cleaned the inside of the pan and magnets.....replaced the filter with a new one......and put the pan back into place.
Then I filled the pan with new ATF.....through the dip stick tube.
Now.....starting with a pan full of clean fluid, I removed the tranny fluid cooler line that has the fluid flow BACK INTO the transmission........at the metal line on the transmission.....and directed it into a container.
On my 2003, it is the line that goes into the metal tube that is more to the driver's side.
Then I started the motor and let it idle.....and watched the fluid flow out of the cooler hose.....and when the flow slowed, or got bubbles in it.....I turned the motor OFF.......measured the amount of fluid that came out......and added the same amount of new fluid.
I did the cooler line drain and fill about 3 or 4 times, using about 11 quarts of tranny fluid TOTAL for the pan drop and cooler line exchange.
wiswind is offline   Reply With Quote
