Originally Posted by Mr. Detail
Typesix, you are stating that I don't even need the 9 volt gadget to reset?
Right. The purpose of the 9-volt gadget you're referring to is solely to preserve system memory(s) when the main battery is removed or replaced. (You can achieve the same thing, if you're careful, by attaching a car charger to the battery cables before you disconnect them, to keep 12-14 volts in the system while the battery's out.) That memory-keeper gadget has no role in the interval-reset procedure.
Are the model year's different with this procedure? (i.e. 2004 vs 2006)
Nope. 2005 is the same. (To be specific, I believe this reset procedure clears several memories in sequence, depending on how long you leave the button depressed. The oil-change interval reset is the first to occur. You can see a little visual countdown in the odometer while this is proceeding. The manual should have further details on this; I confess I haven't looked at that section for a while.)
