Condensation inside headlights - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 04-20-2011, 07:56 PM   #1 (permalink)
View gman62's Photo Gallery
I am looking at an 04 Sienna which has condensation on the inside of the headlight cover. Is this an expensive repair?
Thanks
gman62 is offline   Reply With Quote
Old 04-21-2011, 08:03 AM   #2 (permalink)
Gameroom cash: $239210
View aanders's Photo Gallery
Does the condensation pose a problem? Since these units are not sealed I suppose you can remove the bulbs and vacuum out the moisture or blow hot air into it, Wonder how the water got in maybe a small crack or the rubber o-ring on one of the bulbs is bad.
aanders is offline   Reply With Quote
Old 04-21-2011, 09:57 AM   #3 (permalink)
Yes, I assume the rubber seal/gaskket around the outside is bad and letting mositure in. I do not think it is an issue other than cosmetics.
Old 04-21-2011, 11:37 AM   #4 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
This is a common problem of some Toyota Sienna, Lexus RX330. Mostly on the passanger side. I had this problem before, it fogged up every time I washed my car. I had it replaced under warranty, otherwise it would cost $370 for the light + labor. It can be a DIY, you need to do a search.
Never, never pick up that light from eBay (because most sellers are selling their BAD headlight)
grandpapa is offline   Reply With Quote
Old 04-21-2011, 09:12 PM   #5 (permalink)
Thanks for the info, plus you are correct as it was on the passenger side!!
I assumed it was a little bit costly, otherwise the dealer would have fixed it.
Old 04-23-2011, 12:44 AM   #6 (permalink)
Dealer really don't want to spend any money on fixing car up. You can tell them to fix it (as part of the deal or have them pay 50%)
You don't have to replace it. In my case, it only fogged up when I spray water directly into the housing. You can cover it up when washing. Regular rain, no problem.
