Transmission Fluid - to change or not - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 05-27-2011, 07:30 AM   #1 (permalink)
View wdaltman's Photo Gallery
Hello, I just bought an 06 Sienna LE with 60k miles. Next month, we'll be taking a 10,000 mile camping trip out west pulling a small luggage trailer (around 600 lbs loaded). The transmission fluid has not been changed and I'm wondering if it would be a good idea before this trip. In seeking advice, I've heard everything from never change it to change it regularly, but it might be too late to begin doing that. However, I understand that this is included in the 100,000 scheduled maintenance.
Advice? Should I go ahead and have it drained and filled?
wdaltman is offline   Reply With Quote
Old 05-27-2011, 08:07 AM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260740
View Yuko's Photo Gallery
The 06 should use the T-IV ATF and at 60k, it is perfectly safe to do a drain and refill or a complete fluid exhange. (but never a pressure flush)
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 06-01-2011, 02:00 PM   #3 (permalink)
View torch1025's Photo Gallery
Does this involve just undoing the hex drain plug at the bottom of the transmission let drain completely then fill back up? I am having a hard time figuring if that is the drain plug or not since I know ZERO about transmissions! Please advice and thank you in advance!
torch1025 is offline   Reply With Quote
Old 06-01-2011, 02:14 PM   #4 (permalink)
Yes, that's exactly it. The drain plug is a hex and is under the driver's side. I'm going to be doing this tomorrow, but my understanding is that you remove the plug, catch the fluid, replace the washer (it's apparently a crush or compression washer that is meant for one use, though I think it can be used a few times before being replaced) and replace the 4 quarts of fluid. The conventional wisdom here seems to be that it's best to the oem fluid that you can pick up at a dealership. I paid about $5 / quart and a few bucks for the washer.
Old 06-01-2011, 02:33 PM   #5 (permalink)
Awesome
Thanks for the information! Yes the dealership wants $90 to do this service and I believe I can do it for about $25 ($5.45 per quart X 4) (drain plug gasket $1.51) I might even do this service three times to really get some good fluid in there. This will still be cheaper than the dealership and I will have 12 quarts of good fluid in there. I am not sure what that ratio would be, but it would be almost new. Thanks again for the reply!
Old 06-01-2011, 02:35 PM   #6 (permalink)
let me know
Hey, let me know how the service goes! I am curious to know! That seems like a big hex head, any specific tool?
Thanks
Old 06-03-2011, 02:24 PM   #7 (permalink)
View JoeFoss1's Photo Gallery
Thanks
It is a 10 mm Hex.
JoeFoss1 is offline   Reply With Quote
Old 06-03-2011, 07:25 PM   #8 (permalink)
View racerd's Photo Gallery
Make sure you can access and remove the "fill" plug. No point draining a transmission and then not being able to re-fill it.
2005 LE AWD
racerd is offline   Reply With Quote
Old 06-04-2011, 08:57 PM   #9 (permalink)
The fill port for the Sienna transmissions is the dipstick tube.
The Following User Says Thank You to JoeFoss1 For This Useful Post:
sfhondapilot (06-16-2011)
