2007 Sienna tranny pan - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 07-02-2011, 12:32 AM   #1 (permalink)
View Mikeman's Photo Gallery
New to the forum and relatively new to Toyotas. Has anybody removed the tranny pan? I was going to do a tranny fluid drain, drop the pan and clean it before filling with new fluid. However, I took a look underneath and there is a frame member that is pretty close to one corner of the pan. I was wondering if there's enough room to get the bolts out and drop the pan. Looks kind of tight.
Mikeman is offline   Reply With Quote
Old 07-20-2011, 12:26 AM   #2 (permalink)
Well, I gave it a go and then gave up after spending half an hour trying to get ONE stinking bolt off the pan. I started with the worst bolt and tried every trick in the box that I had. Access is just plain bad. I could have gotten the bolt off. I gave up because I starting thinking about trying to get that bolt back in. You can't really get your fingers on it to spin it and I hate starting a bolt with a wrench and not by hand. I'll have to reformulate my strategy. The great Toyota manual says to "remove the pan by removing the 18 bolts". Yeah, right. Maybe the transmission mount has to come off and the tranny jacked up. Toyota let me down. It really shouldn't be this hard.
Old 07-20-2011, 01:02 AM   #3 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260740
View Yuko's Photo Gallery
I think the mounts might be worn and collapsed a bit. You can try to jack up the engine a bit with a floor jack and wood block to see if it gives you some clearance. I had a similar problem removing the oil pan on an 02 Camry, had to spent some time with a tiny 10mm wrench to remove on bolt hidden by the sub-frame.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 07-22-2011, 05:37 PM   #4 (permalink)
View jo-e90's Photo Gallery
Also, those 18 bolts need to have thread lock on each one. How are you suppose to get all 18 in and tightened before the loktite dries?
jo-e90 is offline   Reply With Quote
Old 07-24-2011, 09:30 AM   #5 (permalink)
View wernermeister's Photo Gallery
loctite is an anaerobic thread locker that cures in the absence of oxygen (= once the threaded connection is done and seals the air out).
No worries about drying.
wernermeister is offline   Reply With Quote
Old 07-24-2011, 04:09 PM   #6 (permalink)
The Toyota Service Manual says on step 10 c) of transmission valve body assy. (U151E/ U151F)" NOTICE: Apply the seal packing or equivalent to the bolts and tighten them within 10 minutes after application because the bolts should be seal bolts."
Old 07-30-2011, 01:29 PM   #7 (permalink)
well, sure, once you screw them into the holes the "curing process" starts...
just set that beer down for the few minutes it takes to get the 18 screws in and torqued down... then grab it an done
Old 07-30-2011, 07:58 PM   #8 (permalink)
View TOYOTAndy's Photo Gallery
Ive done them w/o doing the following by just using a universal socket/ ratcheting flex head wrench, but you can jack up just to the left of the trans-pan using a block of wood. DONT jack up by the trans pan- (it will dent bad and you could damage the filter/valve body), then undo the transmission mount and should give you a better angle at those several bolts, otherwise you'll need a 1/4 10mm universal socket to get to those bolts. I just used the toyota black sealant on the bolts.
TOYOTAndy is offline   Reply With Quote
Old 08-02-2011, 12:06 AM   #9 (permalink)
I tried the universal socket and it was no go. Between the bolt and the frame is less than the depth of the socket. The only thing I could get on was a box end wrench. What year did you do this one?
