Changed the oil today - glad that's done
I changed the oil in my Sienna today, and it was one of those jobs that gives one experience. I bought the van used with 83,000 miles, and it had been in fleet service with a pharmaceutical company, being driven by one of their reps.
You know what you're going to run into with a vehicle that's been serviced by someone else (and in this case, not by a dealer). The first thing I found was what appeared to be a drip coming off the drain plug on the pan. Was it oil? Nope, blue RTV sealant. Apparently the rubbery coating had come off the drain plug washer (or it was just a plain washer), so someone had sealed it with blue RTV.
I was fortunate to have a drain plug that had come off of one of my Previas (I had installed Fram Sure-Drain kits on both my Previa and my F-150). The plugs were identical, so I was able to swap the washer over to the plug for the Sienna, after cleaning the RTV off of the sealing face on the pan.
Next, on to the filter. I put my 3/8" drive ratchet and extension on the filter drain plug, but did the plug come loose? No, the entire filter canister, of course. I figure that the people changing the oil were in the habit of removing the canister with the 3/8" drive, and not bothering with draining the oil first. I got the canister loose, then tipped it so that the oil would run into the drain pan, then set the filter element on the peg molded into the pan. I cleaned the canister with carb cleaner, then clamped it in a bench vise, so I could get the drain plug out. It took an 18" breaker bar with a 1/2" to 3/8" adapter to break the plug loose. Definitely more torque than the recommended value (9.5 ft-lb +- 2 ft-lb).
I got everything cleaned up, then oiled and installed the new o-rings. After cleaning the inside of the adapter housing on the engine, I lightly oiled it, too, to make sure the o-ring would go in smoothly. After installing the element and canister (20 ft-lb of torque) with the cast aluminum 64mm wrench (the wrench was such a snug fit that I had to tap it with a hammer to get it off of the canister), I installed the plug and torqued it to 10 ft-lb.
Since the plug wouldn't come off by itself, I didn't get to try out something I found at Walmart while looking at filters there. I had bought some Toyota filters at the dealer, but I wanted to see what Fram's filter was like. Theirs (I'm not a fan of Fram's oil filters) includes the o-rings, and their own design for the drain pipe, which is a better design than Toyota's. Instead of a pipe that has to be pushed into place, the Fram drain pipe is black plastic, and threaded, so that it screws into the threads used for the plug. A pin in the middle pushes the drain valve open as the pipe is screwed in. Maybe I'll get to use that next time.
Thanks to having to undo someone else's work, a job that should have taken less than an hour ended up taking more than an hour and a half.
Regards,
Steve
'08 Sienna LE FWD
