You can probably find one online for a couple hundred. They are pretty easy I believe I cant remember off this year. It's right behind your glove box.
Step 1: Remove your glovebox by squeezing the 2 sides in and pulling down and also remove the little stopper on the right side of the glovebox.
Step 2: The ECM is a big Grey Square. Unplug all the connectors on the ECM, there is 4 I believe (You just squeeze the tab and pull)
Step 3: Once out, you will see 2 screws. Remove the screws and then on the right side you will see a plastic tab holding a wire harness. Stick a flat blade screwdriver and pry out till the tab pops out.
Step 4: Grab the ECM push back then lower and back towards you and then it's removed.
Step 5. Install is reverse of removal.
Step 6: Take it to the dealer and have them reprogram your VIN into the NEW ECU. Without doing this your ECU won't set off the right information.
Good Luck!
