It all depends on whether you want to do the whole 100k service or not. Most shops are going to rec. you replace all fluids, trans, power steering, coolant, brake and fuel system. That alone your probably looking at $600 maybe even more. At 100k it's also reccomended to replace your spark plugs and have your Timing Belt and Water pump replaced. This could range into the thousands at a dealer. I work at a toyota dealer and giving you my honest opinion, don't worry about the fuel system cleaning. Have your brake fluid flushed next time you get your brakes replaced. That leaves
Trans Fluid
Power Steering Flush
Coolant Flush
Spark Plugs
Timing Belt
Water Pump
Between those 5 things your probably looking close to $1500 - $1600, This is at the dealer remember.
