before or as you are securing the proper spare tire and wheel you need to insure you get all the other jack and lug wrench equipment to change the tire.
my 2008 model has a special part that fits the lug nuts, this part then attaches to the wrench you use to loosen and tighten the lug nuts.
1st: get your owners booklet out and read, insure you have all parts.
some salvage yard should be able to get you the parts you need.
then when you have some spare time:
do as we did, have a practice run: jack the van up, take a tire off, install the spare, drive the van, return to driveway and take the spare tire off, install the reg tire and secure all your tools.
note: if you cannot loosen the lug nuts with the tools that came with the van, you will need to have your tire store tighen your lug nuts with a torque wrench.
you should know the lug nut torque requirements or specs.
no good to have all the tire changing tools, if you can not get the tire lug nuts loose.
glad you found the problem before you needed the spare tire someday when you are in the backside of nowhere.
