Weird Light Issues
I have a 2005 LE, and about a week ago the passenger side door would not unlock with the remote or the switch inside the Sienna. Tonight I went to get in the Sienna and the rear interior lights went out and then just went on. I closed the doors and went to lock the vehicle and the 1st time I pressed the remote it locked the doors, then I pressed the remote the 2nd time to turn off the lights and it didn't beep or turn off the interior lights or headlights. I opened the doors and tried again and the same thing happened. So I opened the doors switched the headlights and the interior light switch to off and closed the doors and locked it.
Any ideas if it could be a relay or might it be a short or fuse? I called the dealership and they said I should bring it in (which I plan on doing) but was just wondering if anyone else had this kind of problem, and if you were able to fix it. Also, I have the Certified Platinum Extra Care so if it was some sort of short or wiring issue it should be covered, correct?
Thanks for your help,
Tony
