Occasional Misfire Starting and Continuous Cranking
Hi all, I have an 07 Sienna, and twice this winter have had a misfire code when starting the van. Once was P0306, the other was P0304. The van started rough and ran rough both times. If I turn it off, to try a "reboot" both times I have then had trouble starting it, and when I release the key from "start", the starter keeps cranking the engine over for a few more seconds.
Both times it was cold weather, but not unusually cold for these parts(today -10C, 14F). In both cases, I turned off again, and it started fine with no light and no bad running symptoms after that.
I suspect this is going to be hard to diagnose if the problem fixes itself and goes away, but does the starter continuing to crank on its own suggest anything perhaps??
Thanks,
Peter
