Front Suspension Questions! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 2nd Generation (2004-2010)
2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
Old 02-06-2012, 01:17 PM   #1 (permalink)
View weener0000's Photo Gallery
Canada Front Suspension Questions!
Hello Toyota Nation.
I am new to the world of modern Toyota. The last one I owned was a '90 pick up and I loved it.
I am going to attempt front suspension on a 2005 Sienna and have a few questions. I have done suspension installs on plenty of VW's but never on a Toyota.
-are they any special tools required?
-what parts should I replace?
-how long does this project take?
thanks for the help!
matt
weener0000 is offline   Reply With Quote
Old 02-08-2012, 02:21 PM   #2 (permalink)
View toyotoyo's Photo Gallery
matt
it depends...
do you want to replace only the strut or the whole assembly (like quickstrut)?
toyotoyo is offline   Reply With Quote
Old 02-08-2012, 02:46 PM   #3 (permalink)
I was planning on just replacing the strut inside the existing spring. i have spring compressors so that portion isn't an issue.
thanks!
Old 02-20-2012, 10:42 PM   #4 (permalink)
View XKWISIT1's Photo Gallery
Canada
The struts are pretty easy to replace. What I usually do is mark the strut mount and insulator and spring with tire chalk to make reassembly quick and painless. If the Sienna has high mileage than I would replace the strut mounts also, and since the swaybar end links had to be removed from the struts; you may want to replace them at the same time if there are any signs of play in the joint.
XKWISIT1 is offline   Reply With Quote
