2004 Sienna Rear Heat Not Working - Toyota Nation Forum : Toyota Car and Truck Forums
Sienna 2nd Generation (2004-2010) Discussion area for the second generation Toyota Sienna.
post #1 of 5 Old 11-24-2009, 08:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA 2004 Sienna Rear Heat Not Working
Any ideas?
Front heat works fine, the rear heat blows cold...
rkg879 is offline
post #2 of 5 Old 11-25-2009, 09:01 AM
Quoted: 0 Post(s)
Check your coolant level and if you need to add, do it when the car is cold and use the same brand/quality that it's already used in your car. Beware of not creating air pockets inside the system.
I had the same problem and it fixed mine.
Hope this helps.
toyotoyo is offline
post #3 of 5 Old 11-29-2009, 06:07 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Well the reservoir was completely empty, Just topped off last night and I know noticed that its been either leaking out/boiling out overnight, maybe about a cups worth in the garage..
What now? (thanks by the way)
rkg879 is offline
post #4 of 5 Old 12-07-2009, 04:11 AM
nazawale's Avatar
Quoted: 0 Post(s)
Canada
I do have the same issue, checked coolant level which is ok. What else to check?
nazawale is offline
post #5 of 5 Old 12-13-2009, 02:31 PM
Quoted: 0 Post(s)
the coolant pipes that run heat to the rear are ran on the inside bottom of van along wall and cool off the coolant befofe it reaches rear, I have 04 as well in canada and my buddy a tech at toyota 20 yrs and ex[lplained this to me . 04 was only problem year, after that they re routed pipes,. it cant be fixed, but when you accelerate it should send warm air to the back as well from rear heater.But take foot off gas or when stopped its cooler,.
dcampbell68 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > Sienna 2nd Generation (2004-2010)
User Tag List
Linear Mode Linear Mode
Back
