You did not indicate what year, but if it is 2004-2007 there are two bolts holding the pump , loosen both - one at rear of pump and one between pump pulley and crank pulley, the one towards the crank pulley, front of car is in a slotted bracket, you have to use a pry bar to put tension on the belt, probably need to remove front wheel and plastic inner fender access plate to see what you are doing. How the heck did you change the belt without doing this?
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
588.4K members
Since 2001
