Originally Posted by 84Cressida
I have the exact same problems you do. I went on the Scotty Kilmer website and he told me it is excess heat causing a gas build up in the engine. If you rev the engine it will clear out and run normally right? He said his Cressida does the exact same thing (he has an MX83!) He says a special winter gasoline formula causes this problem and to fix it would involve re doing the whole vaccum system.
Wow! Haven't though of that! When it happens, I only "blip" the throttle a little to keep it running, but I've never really "revved" it. I did figure it would be a possible vacuum problem, but the "gas build up" thing confuses me a little (and the first time it ever happened to be was in the summer, if my memory serves me right). Thanks for the suggestion and I'll explore this!
