Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Its Time! 8th gen corollas FAQ
View Single Post
Old 04-16-2009, 08:38 AM   #6 (permalink)
hokie_sti
View hokie_sti's Photo Gallery
Here's some really generic brakes/steering diagnosis (I've seen this asked a bunch of times in the last few months):
1. The steering wheel shakes/vibrates at certains speeds. This is usually due to the wheels/tires being out of balance. A quick and free check would be to rotate the rear wheels/tires to the front (assuming the rear wheels/tires are in balance). Get the wheels/tires balanced and rotated at your local tire shop.
2. There is vibration/shaking when I'm braking. This is usually due to "warped" rotors. You can try to re-bed the brake pads to the rotors. If this doesn't work you should replace your rotors and possibly replace your brake pads as well.
3. The car pulls left or right when I take my hands off the steering wheel. This is usually due to the car being out of alignment. Get the car aligned.
- 2008 Subaru Impreza STi (mine)
- 2002 Toyota Corolla CE (hers)
hokie_sti is offline   Reply With Quote
