weak spark 79 cressida
engine is back together,everything is plugged in right but engine wont start, got enough gas, plugs are routed right,timing chain reads proper. but spark wouldnt start a lawn mower its soo weak. car started just fine before but had a blown head gasket. after disassembly and cleaning and sleepless nights putting the 4 miles of vacuum tubing back where they belong the motor came together nicely and is correct in every way. i find it hard to belive the ignitor could be bad and the coil checks out fine. i have a distributor coming in just in case but if i stab a new distributor in and still nothing what could it be? also i cant say if they worked before but i noticed that the gauges dont work at all . the ESP still functions the idiot lights work but no tach or speedo? norelay thta i can find and i took the cluster and the harness is just fine so what now? and yes i hooked the grounds back upp as they came off so i have no idea now. in the proccess i now own the chassis manual the emission manual and the 4m manual maybe ill look for the electrical manual.
