Hitch install over the weekend - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 05-09-2011, 09:49 AM   #1 (permalink)
Biggoldfish's Avatar
View Biggoldfish's Photo Gallery
So I ordered a Draw-Tite hitch on ebay from ecustomhitch on Wednesday and it showed up on Thursday. Wow! Fast delivery. That was the weekend project. Here's what I did, sorry, no pics.
1) Since I have an inclined driveway and a pair of rhino ramps, I placed the ramps under the van and had it all positioned at the top of the driveway to give me and my ample gut room to move.
2) Since the van hadn't been run for a couple of days, it was cool enough to work on right away. But if you used the van beforehand, make sure the exhaust pipe is cool to the touch cause you WILL need to touch it.
3) I laid down a large thick blanket under the work space to keep me comfortable and to catch things if they fall and won't roll away.
4) Starting from the driver's side, remove all the plastic plugs and screws you can find that hold the plastic shield up to the bottom of the cargo area. Move over to the passenger side and continue until you have all the plugs and srews removed. Hence the thick blanket. You will find that the shield is still held up by four screw-type pillars. Use a large flathead to unscrew them. Do not push against them or they will reseat back onto the bolts welded to the cargo area. Let gravity drop the shield as you enscrew each one. When everything is off, SAVE everything!
5) Oh yeah, wear eye protection cause there will be debris falling into your eyes during all this. There were push pins covering the boltholes so I just popped them out, you can throw those away. They are located on both sides of the cargo area. Here's the part where you might want to have a buddy help you, but I did it myself.
6) Working from the exhaust pipe side, wiggle the tang until you can handturn a bolt into the bolthole to secure the hitch into place. I used the uppermost hole so there's maximum movement allowed for adjustments. Them I did the other side's bottom most hole to even it out. Again, hand tight. After screwing in all six bolts, use a ratchet set to tighten the bolts the rest of the way. I didn't have a torgue wrench so I tightened the bolts until I couldn't turn them anymore. All the while doing a criss cross pattern on the bolts like you would a wheel.
7) The instructions said the plastic shield had to be trimmed of 90% off it, but I reused the whole thing. I did have to cut off the two pillars near the rear edge of the shield to make it slide between the hitch and the cargo area. I also had to make a cut along the driver's side part of the shield to let the hitch come through. Then I used black zip ties to close the cut. There's a hump that runs along the whole rear of the shield that just so happens to be at the exact spot of the hitch so I flattened it out and the whole shield slid into place. I then used all the screws and plastic plugs to hold the shield back into place(remember I said to save all those?).
Actually, it tool longer for me to work out the procedure to put the plastic shield back into place than it took me to put the hitch on.
Thanks for reading my loooooong post and I hope it helps you in any way to install a hitch yourself and save you some money. Any questions or comments are welcome. BTW, the manufacturer number is 51080-986 from Draw-Tite. Cost $125.69 total. Free shipping. HTH.
Big gold fish is what my sons call the Sienna! LOL!!!
H11s conversion to H9s
9005 Sylvania SilverStar Ultras Looks the same as stock though...
Drawtite hitch
6" Stubby antenna in glossy black
Aftermarket fog lights
More to come!
Biggoldfish is offline   Reply With Quote
Old 05-09-2011, 01:40 PM   #2 (permalink)
View Seanzky's Photo Gallery
See #7.
Excellent advice. I did the same thing, though I had mine torqued at Mobil at the corner of Norther and Utopia. I didn't have an extender to my ratchet anyway.
I think if you just cut through the panel instead of removing it, cutting, and then replacing, it would have been easier and cleaner. No zip ties for the flapping parts. The only risk is that if you miss, the hole will get bigger and bigger. LOL.
Another reason why I just cut through based on the instruction sheet.
Nice price. I bought my Curt from Amazon for $122. How do you like the Draw-Tite?
--Sean
Bachelor days: '06 Mitsubishi Eclipse GS (fully loaded, Sunset Pearlescent)
Husband days: '08 Nissan Roguel SL AWD (semi-loaded, Brilliant Silver)
Present daddy days: '11 Toyota Sienna XLE AWD (no packages, Super White)
Seanzky is offline   Reply With Quote
Old 05-09-2011, 02:14 PM   #3 (permalink)
RE: #4 & 7. Yeah, I get redundant sometimes...LOL!
I don't have an extension either, I just tightened until I saw the ratchet was kinda flexing and I guessed there was enough pressure exerted!
But if I left the shield in place, I still would have had to tackle that bump! Besides, I took your advice about removing the shield in the first place! And the hole is just enough for the metal part to poke through. And the zip tie is black so it matched perfectly with the glossy black finish of the hitch. The good part of it is that I still retain the coverage of the shield tp protect the undercarriage.
I have to thank you for pointing me in the right direction and making me want to do this mod cause you made it sound so easy. Funny you should ask, I forgot that I had the hitch on when I accidentally drove off a small curb and I heard/felt a crunch/bang from the rear. I thought I ripped out the back of the van. I pull over and realize it was the hitch hitting the curb! Talk about relieved! No damage I could see and the hitch stayed in place and was strong as ever. But I do feel that I'm kind of back-heavy now when I drive. You feel that way?
Drawtite hitch
More to come!
Old 05-09-2011, 02:37 PM   #4 (permalink)
No doubt you did a good job with the install. I wasn't saying you did it wrong or anything like that.
I don't know if you remember but I had that same accident last time off the Waldbaum's ramp on Franny Lew. I don't know if that would have happened had I not put the cargo carrier and deflated the Air Lift bags to minimum pressure, but when I got home you best believe I put the 15psi back in the bags and took the cargo carrier off. LOL. After that incident, I'm never putting anything on my hitch again with only 5psi in the air bags. No sir. Those curbs are mean.
But all the props to Curt for that hitch. It didn't even scratch it! Seriously. Not a scuff on it. Maybe a little bit of the coat came off (out of the billion of layers) because when it slammed down on the curb, I swear it sounded a lot like Armageddon. Lol.
--Sean
Old 05-09-2011, 03:01 PM   #5 (permalink)
Yup! They really powder-coated the heck out of the hitches! No damage but what a noise! LOL!!! You have a cargo carrier for the hitch? I'm gonna look into a back bumper guard for the hitch. Something like steel spikes! LOL!
Drawtite hitch
More to come!
Old 05-09-2011, 03:09 PM   #6 (permalink)
Yup. For coolers and whatever I can bunjee cord to it as well as my mountain bikes. I bought those fork mounts and bolted them on the carrier. Nice and multi-purpose. :-)
--Sean
Old 05-09-2011, 03:11 PM   #7 (permalink)
Got pics???
Drawtite hitch
More to come!
