Push Button Start on dash - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 05-12-2011, 06:50 PM   #1 (permalink)
sfcadams's Avatar
View sfcadams's Photo Gallery
Anyone added a push-button start to their 2011 Sienna? I am referring to a button on the dash that you would push to start the vehicle. I know you would have to have the key in the ignition to unlock the column but then you could just push the button to start it. I believe this is even an option on some models. Just curious if anyone has done it or if it would be easy to just purchase the switch and relay from Toyota and try and figure it out?
sfcadams is offline   Reply With Quote
Old 05-13-2011, 12:24 AM   #2 (permalink)
sfcadams's Avatar
anyone got any idea at all??
Old 05-13-2011, 08:31 AM   #3 (permalink)
View bullfrog23414's Photo Gallery
Those of us with push button start do not have to put a key into the car to unlock the steering column - there is no "key" per se (just the fob).
I'm definitely a "to each his own" sort of guy, but aren't you essentially just adding a completely unnecessary step in the starting of your vehicle?
Currently: you put the key in the slot, turn it and the car starts.
What you are suggesting: you put the key in the slot, turn it, the car does nothing, then you press a button and it starts.
Seems a little silly.
I think it's possible to do, probably fairly simple actually. You'd cut the ignition wire from the key hole, and re-run that wire to a button that you place on the dash board.
bullfrog23414 is offline   Reply With Quote
Old 05-13-2011, 03:33 PM   #4 (permalink)
Gameroom cash: $130500
View MatrixPC's Photo Gallery
you can wire a push button type in parallel with the start wire from the ignition lock to push it. I think the S2000 config is like that. You insert the key and turn it to ON, then push the button to start the engine instead of turn the key pass ON mark to start the engine.
Man I pay extra for the no so useful Nav system just to have that "high tech" start button. ;
2012 Camry Hybrid XLE Cosmic Gray/Ivory
2011 Sienna XLE Super White
89 Supra Turbo HID Conversion
89 Supra Turbo LED Conversion
89 Supra Turbo CarPC
2004 Matrix XR CarPC A moron in a Civic Hit n Run. Total loss.
MatrixPC is offline   Reply With Quote
Old 05-13-2011, 05:06 PM   #5 (permalink)
View Jeff194's Photo Gallery
You could add a remote starter.
Jeff194 is offline   Reply With Quote
Old 05-14-2011, 07:38 PM   #6 (permalink)
Gameroom cash: $198200
View skinny2's Photo Gallery
I'm sure you could do anything if you wanted bad enough. I have the push-button from the factory and frankly would prefer to just have the old-school key. It's not bad on a normal car but with having to access the fob for the sliding doors or rear-hatch...the thing is in my hand anyway. I would assume it just stay there through the process. I'm also not a fan of you can't shut the car off and leave the radio running (without hitting the button to restart in accessory mode). Unless I've not figured out the trick to that yet....
2011 Sienna Ltd
2010 Camaro SS
2008 Patfhfinder
skinny2 is offline   Reply With Quote
Old 05-16-2011, 04:58 PM   #7 (permalink)
I'm with you on the radio thing.
It's stupid that if I just want to shut down the engine and leave the radio on, I can't. I have to "cycle" back to the radio accessory mode from OFF.
anyone find a trick to "shut off the engine but leave the accessory mode on"?
Old 05-16-2011, 05:34 PM   #8 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
The Ford GT had this, and it's easily added to the 2005+ Mustangs
Nope, you gotta cycle back. PITA, I know...
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 05-17-2011, 07:11 AM   #9 (permalink)
Biggoldfish's Avatar
View Biggoldfish's Photo Gallery
Did that button start on my previous vehicle. Used a starter mometary switch from AZ and a couple of wires. I had to run the wires into the cabin and back out and mounted the button near the ignition key. Like bullfrog said, why add a step just to start your car? I did it cause my neutral safety switch sometimes would be confused and think it was still in "D" instead of "P". Worked out great.
Big gold fish is what my sons call the Sienna! LOL!!!
H11s conversion to H9s
9005 Sylvania SilverStar Ultras Looks the same as stock though...
Drawtite hitch
6" Stubby antenna in glossy black
Aftermarket fog lights
More to come!
Biggoldfish is offline   Reply With Quote
