Originally Posted by akphs
Are you sure? I thought that was traction control. VDIM is supposed to integrate traction control, ABS, et al., and to work quietly and seamlessly most of the time. I'd be surprised if it flashed and beeped every time it kicked in...
Positive. The little traction icon will flash at you when traction control is activated, but if it beeps at you too then thats the full VDIM. It takes a lot more to get the full VDIM to intervene, and when it does it will alert you because you are driving beyond the limits of the vehicle. It beeps at you because you are doing something wrong (or right depending on how you drive
) and pushing it beyond what Toyota deems safe. Traction control intervention could be for something as simple as too much throttle from a dead stop. You don't need it beeping at you every time that happens.
There is nothing quiet or seamless about VDIM. You'll know when its activated - engine power is cut, throttle response is scaled back almost entirely, you can hear and feel ABS kicking in. Toyota stability programs are passive/reactive systems, they are not proactive systems like those you would find in AWD vehicles with torque-vectoring.
