HID for DRL and High beam - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 07-12-2011, 03:52 PM   #1 (permalink)
View spiceboy23's Photo Gallery
Canada HID for DRL and High beam
Hi all,
I finally had a chance to install my HIDs for the DRL over the weekend. Things didn't go as smooth as I hoped though.
Questions:
1) Both DRL and high beam shares the same bulbs, right?
2) After installing the bulbs without a relay, I blew the fuses on the high beams. Got replacements from dealership, re-installed again with relay, and got the high beams working. But now the DRL doesn't turn on. I checked the fuse for the DRL and it seems intact. Am I doing anything wrong?
3) How do you replace a fuse for DRL? The Sienna fuse box comes with a little fuse removal tool but is only good for "Type A" (e.g. high beam) fuses. The other fuses are bigger and boxy, and most of them have a clear plastic cover on top so you can tell if the fuse is broken from just looking in. However, even the user manual says "Contact Dealer" if one needs to replace one of these fuses. I'm just wondering if any of you has experience replacing these yourself. If so, how?
I just want to make the DRL working before proceeding with the installation of the HID fogs ...
Thank you for your feedback in advance.
spiceboy23 is offline   Reply With Quote
Old 07-12-2011, 05:38 PM   #2 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1002564
View humanoid's Photo Gallery
IIRC you can't have HIDs in your DRLs because the DRLs operate at 50% of the highbeams, the HIDs don't have enough power to light up, thus they don't work.
This is my sig.
humanoid is offline   Reply With Quote
Old 07-13-2011, 06:48 AM   #3 (permalink)
Biggoldfish's Avatar
View Biggoldfish's Photo Gallery
Agree with humanoid. The DRLs are only operating at 50% capacity, that's why they are dimmer than when you put the highs on. Even though you have a relay switch connected up to the DRL/hig beam plug, there's just too little power going through the relay to turn on the DRLs. Even if it did, the DRLs will look like regular HIDs cause HIDs DO NOT work on half power. 100% or nothing. Switch back to regular bulbs or if you want, you can use Hellas. They're the brightest, I believe. I have Sylvania SilverStars on my DRL/highs.
Big gold fish is what my sons call the Sienna! LOL!!!
H11s conversion to H9s
9005 Sylvania SilverStar Ultras Looks the same as stock though...
Drawtite hitch
6" Stubby antenna in glossy black
Aftermarket fog lights
More to come!
Biggoldfish is offline   Reply With Quote
Old 07-15-2011, 12:53 PM   #4 (permalink)
View gs3tek's Photo Gallery
V leds carries this kit for the drl hid:
I find it impractical since you can barely see hid in the day time.
http://www.v-leds.com/Exterior-LED/D...60696-1-2.html
['11 Sienna SE]-Silver Sky Metallic
9"DVD headrest monitor, 6x9" Pioneer speaker DIY, Homelink/compass mirror, AVS window visor
5K HID lows, LED interior, LED license plate
gs3tek is offline   Reply With Quote
