Originally Posted by siennaa
Hi gftgrill,
After i connected two wires straight from Denso ballasts to car battery, it work fine. But it's not work when i connected to headlight connector, i did swap oem lexus rx330 projectors for my sienna projector. This complete Oem hid kit set up work fine on 2008 Toyota camry.
After i tried for all kind of ways but still not work then i searched online how to do set up for my 2011 toyota sienna but no help.
Finally i just buy from Ebay headlight relay harness and it work perfect.
My best guess is that the ECU is monitoring voltages based off of halogen headlights. The xenon ballasts are pulling different voltages and your computer is thinking that something is wrong with the headlights and cutting power.
The relay harness is probably your cheapest solution.
Do you have any pictures of the RX projectors in the headlight? Where you able to just unscrew the halogen projectors and do a direct swap or did you have to open the headlights to perform the swap?
