Originally Posted by proprioceptive
Place them where you want. All you have to do is measure yourself. There is no set position. If you're really that worried, then check out a Sienna on the lot that already has them on, measure, transpose. Like I said, easy as pie.
Unfortunately, in Massachusetts, I did not see anyone sienna with these either on the road or at any dealerships. Probably, I will be the first one in MA!
. I do not want to stick anywhere I like, I want to follow proper procedure. Yes, it is not rocket/chemical science but good to follow what Toyota suggests. Hope one of you understands and helps. I will keep asking people/dealers. These are same like body side molding which come with instructions and these ones did not
Thanks
