Toyota Tech Tip and TSB - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 10-16-2011, 07:18 PM   #1 (permalink)
View chanduyaar's Photo Gallery
Canada Toyota Tech Tip and TSB
Tech Tip : 16 document(s) found.
1. T-TT-0060-10: All Models: Adhesive & Sealant Cross Reference Information
2. T-TT-0005-10 Rev6: All Models: Oil Viscosity Applicability and Change Interval Guide
3. T-TT-0025-10: All Models: Spots in Window Glass
4. T-TT-0041-10 Rev1: All Toyota Models: Emergency Locking Retractor/Automatic Locking Retractor Seat Belt System Operation
5. T-TT-0042-10: All Toyota Models: OEM Replacement Body Panel Identification
6. T-TT-0051-10: All Models: Causes Of HVAC Odor
7. T-TT-0054-10: All Models: Best Practices for Brake Fluid
8. T-TT-0079-11: All ATM Equipped Vehicles: Automatic Transmission Replacement Precautions
9. T-TT-0082-11 Rev1: Multiple models and multiple years: BLU Logic Handsfree System - Troubleshooting
10. T-TT-0086-11: Models with Electronic Throttle Control: Hard Start or Poor Idle After 12 Volt Power Interruption
11. T-TT-0092-11: All applicable vehicles: Rear Seat Entertainment Parental Control Password Reset/Initialization
12. T-TT-0094-11: '10-'11 2GR-FE Highlander, RAV4, Sienna: 2GR-FE Cylinder Head Cover Oil Leak
13. T-TT-0095-11: '10-'11 2GR-FE Highlander, RAV4, Sienna: 2GR-FE Engine Oil Pan Leak
14. T-TT-0098-11 Rev1: All Applicable Models: Change to Antenna Installation During PDS
15. T-TT-0117-11: Models with Safety Connect: Telematics Back Up Battery - General Information
16. T-TT-0124-11: All Models: Best Practice for Tire Rotation / Nitrogen Filling
Service Bulletin : 45 document(s) found.
1. T-SB-0005-10: '11 Sienna: Tire Pressure Warning System Initialization
2. T-SB-0006-11: 04-11 Applicable Toyota Models: World Standard Automatic Transmission Fluid
3. T-SB-0008-10: '11 Sienna: Initialization of Power Sliding Door During PDS
4. T-SB-0010-10: '11 Sienna: Short Pin Installation During PDS
5. T-SB-0012-10: '11 Sienna: Initial Calibration of Compass During PDS
6. T-SB-0013-10: '11 Sienna: Initialization of Power Back Door During PDS
7. T-SB-0013-11: 10-11 Applicable Toyota Models: USB/iPod Not Recognized
8. T-SB-0014-10: '11 Sienna: Front License Plate Installation During PDS
9. T-SB-0014-11: All ATM Equipped Toyota Models: Torque Converter Bolt Installation
10. T-SB-0026-10: '11 Applicable Toyota Models: Smart Key System Check During PDS
11. T-SB-0034-10: '11 Sienna: Initialization of Rear View Monitor System
12. T-SB-0036-11: '11 Sienna: SOS Indicator Light Is RED and Bluetooth Microphone Inoperative
13. T-SB-0040-08 Rev1: 08-11 Applicable Toyota Models: Paint Stains Under Rapgard
14. T-SB-0044-11: '11 Sienna: Power Slide Door Abnormal Operation
15. T-SB-0048-10: '11 Sienna: Auto Access Seat Check during PDS
16. 2011 Sienna Pre-Delivery Service Check Sheet
17. T-SB-0053-11: '11 Sienna: Warm Air from HVAC Vents with A/C ON - DTC B1479
18. T-SB-0056-10: 2011 MY Sienna Pre-Delivery Service (PDS)
19. T-SB-0064-10: 01-11 Applicable Toyota Models: Techstream ECU Flash Reprogramming Procedure
20. T-SB-0071-11: Automatic Transmission Replacement Precautions
21. T-SB-0079-09 Rev1: '98-'11 Applicable Toyota Models: Long Term Vehicle Storage Guidelines
22. T-SB-0086-10 Rev1: '11 Applicable Toyota Models: Floor Mat Installation During PDS
23. T-SB-0100-09 Rev1: 05-11 Applicable Toyota Models: Remote Engine Starter (RES) Cold Temperature Operation Diagnostic Tips
24. T-SB-0101-11: All '83-'12 Toyota Models: Interior Electrical Component Precautions
25. T-SB-0104-09 Rev1: '07-'11 Applicable Toyota Models: Oil Filter Cap Assembly Precautions
26. T-SB-0105-11: 05-11 Applicable Avalon, Camry, Highlander, RAV4, Sienna, Venza: MIL "ON" VVT-i DTCs - Oil Control Valve (OCV)
27. T-SB-0116-11: '11 Sienna: MIL "ON" DTC P0116
28. T-SB-0117-11: '01-'11 Applicable Toyota Models: Water Pump Inspection and Diagnostic Tips
29. T-SB-0122-08 Rev1: 04-11 Applicable Toyota Models: Smart Key Battery Diagnostics
30. T-SB-0122-11: '98-'12 Applicable Toyota Models: Seat Cover Replacement For Side Airbag Equipped Vehicles
31. T-SB-0130-10 Rev1: '10 Prius & '11 Sienna: MIL "ON" Code P0456
32. T-SB-0140-11: 11 Sienna: Sliding Roof Side Garnish Loose
33. T-SB-0141-10: 03-11 Applicable Toyota Models: Upper/Lower Windshield/Rear Glass Tick Noise
34. T-SB-0141-11: 11 Sienna: Sliding Roof Inoperative
35. T-SB-0145-11: '06-'12 Toyota Models: Shock Absorber Replacement Criteria
36. T-SB-0146-10 Rev1: '10-'11 Camry, '09-'10 Highlander, RAV4, Venza, '11 Sienna: Brief Engine Knock/Rattle Noise at Cold Startup (1AR/2AR)
37. T-SB-0157-11: '11 Sienna: 3rd Row Manual Seat Rattle Noise
38. T-SB-0161-10: '11 Sienna: 3rd Row Power Seat Will Not Return From Stowed Position Properly
39. T-SB-0185-10 Rev1: '11 Sienna: 2nd Row Seat Ottoman Inoperative
40. T-SB-0204-10: '08-'11 Applicable Toyota Models: Tire Positioning Before New Vehicle Delivery
41. T-SB-0271-09 Rev1: 06-11 Applicable Toyota Models: XM Satellite Radio Inoperative Until Ignition Key Is Cycled
42. T-SB-0345-08 Rev2: '04-'11 Applicable Models: Tire Inflation Pressure Compensation and Adjustment
43. T-SB-0367-10: '11 Applicable Toyota Models: Seat Belt Extenders
44. PD017-04: All Models: Wheel Film for Brake Rotor Rust Prevention
45. PG001-06: Battery Maintenance for In-Stock Vehicles & Pre-Delivery: All Models & Model Years (Revised)
Canada Service Bulletin : 23 document(s) found.
1. T-TCI-1204: All Models: How To Download Tdt Software Versions And Calibration Files
2. T-TCI-1317: All Applicable: Adjustment Of Tire Inflation Pressure
3. T-TCI-2077: All Models: Wheel Film For Brake Rotor Rust Prevention
4. T-TCI-2283: All Models: Battery Maintenance For In-Stock Vehicles & Pre-Delivery
5. T-TCI-3357: '11 All Applicable Models: Smart Key System Check During PDS
6. T-TCI-3360: '11 All Applicable Toyota Models: Floor Mat Installation During PDS (Revised)
7. T-TCI-3362: '11 Sienna: Pre-Delivery Service Check Sheet
8. T-TCI-3363: '11 Sienna: Auto Access Seat Check During PDS
9. T-TCI-3364: '11 Sienna: Front License Plate Installation During PDS
10. T-TCI-3365: '11 Sienna: Initial Calibration Of Compass During PDS
11. T-TCI-3366: '11 Sienna: Initialization Of Power Back Door During PDS
12. T-TCI-3367: '11 Sienna: Initialization Of Power Sliding Doors During PDS
13. T-TCI-3368: '11 Sienna: Initialization Of Rear View Monitor System
14. T-TCI-3369: '11 Sienna: Short Pin Installation During PDS
15. T-TCI-3370: '11 Sienna: Tire Pressure Warning System Initialization
16. T-TCI-3417: '10 Prius, '11 Sienna: MIL "ON" Code P0456
17. T-TCI-3453: '11 All Applicable Toyota Models: Tire Positioning Before New Vehicle Delivery
18. T-TCI-3459: '11 Sienna: 3rd Row Power Seat Will Not Return From Stowed Position Properly
19. T-TCI-3463: '11 Sienna: 2nd Row Seat Ottoman Inoperative
20. T-TCI-3497: '11 Applicable Toyota Models: Long Term Vehicle Storage Guidelines
21. T-TCI-3569: '04-'11 Applicable Toyota Models: World Standard Automatic Transmission Fluid (Revised)
22. T-TCI-3578: '11 Sienna: Power Slide Door Abnormal Operation
23. T-TCI-3581: '11 Sienna: Warm Air From Hvac Vents With A/C On - DTC B1479
chanduyaar is offline   Reply With Quote
Old 12-08-2011, 12:20 PM   #2 (permalink)
View blizprl1's Photo Gallery
Any links to those documents please? I can see where problems will come to me when I start tinkering with ATF, engine oil, brake fluid at the beginning, and these docs will help me a lot.
blizprl1 is offline   Reply With Quote
