The question isn't whether they make chains for the size...obviously you can get chains for any size. The question is if there's enough clearance to run the chains on your particular vehicle. The SE doesn't have any larger overal tires/wheels than the other models (technically 2-4mm at most). My take would be if you can run chains on any Sienna you can run them on the SE. I would think a low-profile chain would work just based on a visual inspection but there's not a lot of room in the wheel wells on these things.
2011 Sienna Ltd
2010 Camaro SS
2008 Patfhfinder
