Clear Main't Req'd light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 11-17-2011, 08:02 PM   #1 (permalink)
View droffats's Photo Gallery
It's not working by:
1. the Camry method (holding down the ODO button w/key in "on"
2. the dealer told me the wrong way (see #1)
3. the forum method isn't working (see #1)
4. can't find it in the manual (when the dealer couldn't do it, he said look in the manual)
Thanks,
Droffats
droffats is offline   Reply With Quote
Old 11-17-2011, 08:19 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Disconnect battery and pull the ECU fuse for 1 minute.
The Jedi Speeder at CarDomain
Old 11-18-2011, 08:28 PM   #3 (permalink)
I know that will work, but isn't there something easier? I mean, the quickie lube guy isn't doing all that...
Old 11-18-2011, 08:57 PM   #4 (permalink)
Gameroom cash: $198200
View skinny2's Photo Gallery
It's in the manual. I changed out our oil at 5k and found the reset instructions. It was some combination of pushing the start button and holding odo button on mine but I don't recall the exact procedure. There were several pages because it's different between the smartkey and non-smartkey. On my previous Tundra you had to turn key to acc then push odo button and hold while turning key to on.
2011 Sienna Ltd
2010 Camaro SS
2008 Patfhfinder
skinny2 is offline   Reply With Quote
Old 11-19-2011, 05:21 PM   #5 (permalink)
Ah HA! The odometer has to be on "trip A". Hold it down, then move the key to "on". It clears in just a few seconds. It is in the manual after the oil change section (it's not in the index though).
Thanks,
Droffats
Old 11-19-2011, 06:12 PM   #6 (permalink)
Tech1984's Avatar
Gameroom cash: $256350
View Tech1984's Photo Gallery
It will show the clearing dashes in the combination meter, or the center multi function display depending on which model. Both types need to be on trip A FYI.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is online now   Reply With Quote
