back up camera always on - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 11-20-2011, 10:18 AM   #1 (permalink)
View padard's Photo Gallery
it is possible drive with back up camera always on ?
thank you and have a nice day
pat
padard is offline   Reply With Quote
Old 11-21-2011, 02:57 PM   #2 (permalink)
View blizprl1's Photo Gallery
You may be able to do that by modding the cables connected from camera to the screen. But how do you want to keep it on all the time? Do you want to connect it to forward gears?
pat
blizprl1 is offline   Reply With Quote
Old 11-21-2011, 05:41 PM   #3 (permalink)
i
my problem is reverse gear signal at screen rest at ground if not on reverse gear . i'm use a relay to open circuit and sending 12 volt only at reverse wire in connector back of screen ,no result . i think is switching by can bus from instrument cluster.
pat
Old 11-21-2011, 06:35 PM   #4 (permalink)
View akphs's Photo Gallery
Heh, I sometimes want to turn it on to see what the car behind me is doing while at a light. Putting the car in reverse seems antisocial. Seems like it'd be nice to be able to turn it on by holding a button down or something; it could enforce the same while-the-car-isn't-moving as the GPS (though of course I'd rather it didn't).
akphs is offline   Reply With Quote
Old 11-21-2011, 07:01 PM   #5 (permalink)
yes i' m installing a switch in glove box because in first time do this job i think make easy, but is not easy .but when flip the switch nothing in screen appears only if put in reverse gear . i would like make this mod to watch my trailer.
thsnk you and have a nice day
pat
Old 11-30-2011, 08:59 PM   #6 (permalink)
View boricua_aoc's Photo Gallery
This is a standard option for the screen on the AVIC-Z120BT. However it only works right after you switched from reverse. It last for a few seconds and then the camera goes black. I'm assuming it goes black after it looses power.
boricua_aoc is offline   Reply With Quote
