3 Questions... - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 12-19-2011, 10:37 AM   #1 (permalink)
Gameroom cash: $306400
View naturoses's Photo Gallery
3 Questions...
Hi All, Hope all are well during the holiday season. Now, I am taking some break from work and hence decided to drive my car more and think about it because I love her. I call my car as "Shining Silver Bird"
Forgive me: I did not use the "search"
Question1:. Do you have ever experienced a popping sound of your back passenger doors? Also, do you hear any kind sounds when closing the passenger door like a rubbing against/grinding/struggling etc. (I do not think I have described it right because it is really not like grinding and struggling...)The door closes, but with some kind of sound and I am unable to describe. I noticed this yesterday. Does it happen during cold season? I always use remote to open doors.
Question 2: When I open the driver's door, I hear a sound from odometer (or may be from that side/region). I feel like a disc turning or something.What is it? It is not like "Click sound" which we hear when unlocking or locking doors...
Question 3: The fake wooden gear stick knob: how far can we thight? If it is too tightened, will we do damage of any sort?
Many Thanks to all
Best Wishes,
Happy Holidays,
naturoses is offline   Reply With Quote
Old 12-19-2011, 11:07 AM   #2 (permalink)
View akphs's Photo Gallery
Many Thanks to all
Best Wishes,
Happy Holidays,
1) Yes, lots of folks, lots of discussion. Do use search, look for "pop" or "popping".
2) If you mean after turning the car off, yes: this is something related somehow to the electronics. Try opening the door *before* turning the car off; the car will "bong" at you, then close the door and you'll hear the noise. I'd like to know what this is myself, just for curiosity's sake.
3) Presumably if you tighten it too far, you'll find it will be loose then aligned correctly. And if you *really* tighten it too far, you'll split the knob, shear the shaft, or hurt your hand
akphs is offline   Reply With Quote
Old 12-19-2011, 11:18 AM   #3 (permalink)
My popping sound occured few times only. I hear a kind of resistance to rolling or rubbing while closing the driver's side passenger door. I think this is due to lack appropriate amount lubricants or cold or ice. Should I be frightened that my Shining Silver Bird is sick and take her to the doctor's.....
Yes, after turning the car Off.
Oh no, I will be careful...
Thanks
3) Presumably if you tighten it too far, you'll find it will be loose then aligned correctly. And if you *really* tighten it too far, you'll split the knob, shear the shaft, or hurt your hand [/quote]
Thanks
Old 12-19-2011, 05:13 PM   #4 (permalink)
AML
Gameroom cash: $214800
View AML's Photo Gallery
2) Electric power steering locking/unlocking.
2011 Chrysler Town & Country Touring
2008 Toyota Camry Hybrid
2003 Yamaha V-Star 650 Classic
2002 Jaguar X-Type 2.5 AWD
AML is offline   Reply With Quote
Old 12-19-2011, 06:31 PM   #5 (permalink)
Is that Right? I did not hear these sort of sounds on 2010 Rav4 and 2010 Highlander and hence asked this question...
Thanks
Old 12-19-2011, 06:36 PM   #6 (permalink)
AML
Thanks
I know it makes the noise on Smart Key equipped ones.
The Following User Says Thank You to AML For This Useful Post:
naturoses (12-19-2011)
Old 12-19-2011, 11:06 PM   #7 (permalink)
View DanielAcosta's Photo Gallery
Many Thanks to all
Best Wishes,
Happy Holidays,
The popping noise is a known issue caused by a timing delay. The fix is a published service bulletin that requires replacing the motor/actuator in the door and is covered under warranty. Takes half a day to do both doors. Until you get it fixed, you can avoid the popping noise by either using the key fob or one of the internal electric buttons, or else holding the handle out until the door starts to move. The pop happens when you pull and release the handle quickly before the door starts to move. Good luck with your repair.
DanielAcosta is offline   Reply With Quote
