well the service advisor is'nt completely wrong. the tapping noises are common. but, all mechanical issues are repairable. sounds like bad advice. first of all if the service rep did'nt hear the noise how can he reassure you its alright? he cant. here's the first thing toyota will tell the dealer in a case such as this.
1 - cold start a like vehicle on the lot, same engine and all. (new is best)
2 - does the noise occur on the "like vehicle"?
3 - now 2 possibilities exist, normal noise or repairable condition duplicated.
at this point I would advise to leave the car late one night, somewhere out of the way on the dealer front lot area. come in next morning when they open and do a short cold start video clip with the service manager present. show him directly (not the service rep that thinks its ok).
I can tell you I have seen many 3.5L v6 Toyota engines with excessive mechanical noise, from VVT-i and other components, that the manufacturer did not want to address unless pressed hard by the customer. your engine however I have never heard anything on, I would ask to cold start another identical model when you go back.
in the recent past I saw a 10 or 11 corolla with a bottom end spun bearing and knocking noises, before first scheduled service, the rotate. stuff happens, keep an eye on it!
