hello and my grey sienna LE on 20's - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Sienna Forum > 3rd Generation (2011+)
3rd Generation (2011+) Discussion area for the third generation Toyota Sienna.
Old 01-29-2012, 04:14 PM   #1 (permalink)
View onespeedpaul's Photo Gallery
hi all, long time lurker first time poster, just wanted to show off my swagger van:
got the wheels from team dynamics ebay store, and the tires are venza size 245/50-20.
onespeedpaul is offline   Reply With Quote
The Following 2 Users Say Thank You to onespeedpaul For This Useful Post:
IQ9 (01-30-2012), jm98 (02-01-2012)
Old 01-30-2012, 12:08 AM   #2 (permalink)
dev
View dev's Photo Gallery
nice!
dev is offline   Reply With Quote
Old 01-30-2012, 12:18 AM   #3 (permalink)
View Jdracer's Photo Gallery
What's the specs on the wheels, width and offset. I have my new 20's for my limited awd but the rears dont fit its hitting the swing arm, I got hub centric spacers on order so hopefully it works out.
Jdracer is offline   Reply With Quote
Old 01-30-2012, 06:32 AM   #4 (permalink)
wheels are 20x8.5, 38 offset. mine have less than a quarter inch clearance, but dont rub. ive got spacers on order too, looing to mae them look more even.
Old 01-30-2012, 11:12 AM   #5 (permalink)
Gameroom cash: $236150
View grandpapa's Photo Gallery
should have a pic with the van in front together
From looking at your van alone, I probably wouldn't have known it wears 20s
grandpapa is offline   Reply With Quote
Old 01-30-2012, 02:47 PM   #6 (permalink)
This makes sense then... my wheels are 20x9.5 +40 so i've got about half inch of wheel inward which hits the rear trailing arm. I wanted to get a lower offset but they did not have them in my wheel choice. I got some 15mm ichiba v2 hub centric spacers on order hopefully it will work.
Old 01-31-2012, 11:46 AM   #7 (permalink)
View cape97's Photo Gallery
hey JDracer.... I dont know if you've seen my threads before but I have made all the Trial and error research on wheels on our Sienna and the most you can go outward while looking completely flush is around a +10 offset in the back and +15 offset in the front on 20X9.5 Wheels with 245/45/20 tires..... you could easily go +25 on the hubcentric spacers just make sure you dont get any cheap brand and that you get H&R.... you're not gonna find a Sienna on their catalog but a Camry is excalty the same hub as ours... hope this helps!!
cape97 is offline   Reply With Quote
Old 01-31-2012, 11:50 AM   #8 (permalink)
The Following User Says Thank You to cape97 For This Useful Post:
jm98 (02-01-2012)
Old 01-31-2012, 11:51 AM   #9 (permalink)
hope the pics help!
Old 02-01-2012, 12:35 PM   #10 (permalink)
Gameroom cash: $290500
View ACS Rob's Photo Gallery
looks good OP!
cape, how difficult was it to replace the lug bolts required for the thicker spacers? did you DIY or had them replaced?
ACS Rob is offline   Reply With Quote
Old 02-01-2012, 12:51 PM   #11 (permalink)
sup rob... I actually got it done at my friend's shop...very typical of other cars and their brake systems. if you know how to do brake discs off a civic you can do it the Sienna. Its funny though because i do have longer studs now but I dont really use it because I switched from 15mm and 20mm spacers to 5mm and 10mm spacers. I switched my wheels to a more aggresive offset like a 20x9.5 +20 offset so I was able to use thinner spacers. Its nice to have longer studs just in case i go back to something with higher offset..
Old 02-01-2012, 03:17 PM   #12 (permalink)
is your buddy's shop in the milbrae area? got a number so i can get an estimate? is this the same person you buy spacers from? if not, want to sell your 15mm?
Old 02-01-2012, 03:31 PM   #13 (permalink)
actually his name is Johnson and he owns a shop called Faxon Garage in Ocean ave. more on the daly city side. his number is 415-713-7539. you can text him and tell him Paul referred you. Pm me your number so i can text you back an estimate "playa price" haha ...Ill think about selling my spacers man hahaha Ill PM you too..
Old 02-01-2012, 03:39 PM   #14 (permalink)
he told me 80 for all 4 corners man... he usually charges 120 for it.. lemme know thanks!
Old 02-01-2012, 04:46 PM   #15 (permalink)
hey cape, any reason you went with 5mm difference front to rear? i ended up going with 15mm front and 25mm rear, sets them just right on mine at least....
