Before I say anything please take anything I say as a grain of salt and not make any assumptions that I have worked with Toyota and have endorsed my findings. My research is my research alone and maybe a few shops in my local area.
NEW OFFSET LIMITS for the SIENNA!
After seeing the Vossen Sienna and compared my current offsets and setups, the Sienna CAN
do 20x10.5 wheels!
based off my current setup, the closest offset would be a +30
here are the numbers:
current setup:
Fronts: 20x9.5 (+25) + 10mm spacers = 20x9.5 +15
Rears: 20x9.5 (+25) + 15mm spacers = 20x9.5 +10
new setup
Fronts: 20x10.5 (+30) (no spacers) = retracts wheel from current setup by only 2MM... YES!!
Rear: 20x10.5 (+30) (no spacers) = retracts wheel from current setup by 7MM... gonna want to add 5mm spacers to be 2MM different from current setup..
CONCLUSION:
ladies and gentleman!! NEW MOST FLUSHED OFFSET FOR SIENNA!!
20X10.5 +30 OFFSET!!!
now depending on what tire size you guys have can definitely change the situation from no rubbing to possible rubbing... my recommendation:
245/45/20 tire size...cheapest and closest diameter to the original
UPDATE:
- Per Gee702, 275/35/20 tires WILL NOT FIT with this setup!!! so please don't use that tire size!!
THERE YOU HAVE IT FOLKS!! enjoy!!... will be posting pics of my new wheels next week!!!
CHEERS!!
