3VZ oil pan gasket replacement - any thing else?
I'm going to replace the Camry's oil pan gasket soon, and was wondering if there is anything else that ought to be checked or replaced while I'm in there? '92 LE with the 3VZ V6, 285k miles on it. The crank and camshaft seals were replaced recently, and the oil filter adaptor's as well. I noticed the pan leak when I was doing the adaptor seal.
I did a search and didn't find anything. Perhaps because there isn't?
