Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - '87 Cressida Idles poorly after a high speed run
View Single Post
Old 04-19-2009, 10:10 PM   #9 (permalink)
kamesama980
Cressida nut
Gameroom cash: $251045
View kamesama980's Photo Gallery
Originally Posted by 84Cressida View Post
Mine has idled so low to the point that it did stall but it would start back up. What is vapor lock exactly?
fuel gets so hot it evaporates in the fuel lines. the fuel system is calibrated for the density of liquid fuel so the engine doesn't run. less of an issue with FI and return type pressure regulators (unused hot fuel dumps back into the tank to mix with cold fuel and dissipate heat through the tank) was more of an issue with carbs because of low pressures and lines ran next to the engine longer (mech. pump to carb) and a carb sitting on a warm part of the engine
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
