Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - My System for my 01 Corolla
View Single Post
Old 05-06-2009, 06:26 PM   #4 (permalink)
frojoe
View frojoe's Photo Gallery
Originally Posted by SexieWASD View Post
For an amp remember that you will need 400w RMS @ 4ohm. Power ratings on amps go up as you decrease the resistance, so you will need a bigger amp than if you were running 400w RMS @ 2ohm.
I think you have that a bit backwards. At a lower resistance the same amp will create more power. As an example my sub amp provides 220w RMS at 4ohms, but 400w RMS at 2 ohms. You want to wire the sub for the lowest resistance in ohms that your amp is stable to. Some only go down to 4 ohms, but most car audio amps are stable down to 2 ohms. If you hook an amp only stable down to 4 ohms to a 2 ohm load, it will either destroy itself or shut off in self protect.
frojoe is offline   Reply With Quote
